-   Tuning, Diagnostics, Electronics, and Wiring (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-163/)
-   -   5 volt code 1635 (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-163/5-volt-code-1635-a-537070/)
tim wellington Apr 19, 2015 08:42 AM
5 volt code 1635
my brother truck .every now and then it will through a 5volt code .only does it on hard acceleration or fast stops .truck dies starts and cuts right back off .if I pull ignition relay and wait about 2 minutes .it start right back .any suggestions
Richardman1992 Apr 19, 2015 09:46 AM
A quick google search shows that code could be set off by the ac pressure sensor, the map sensor or the egr valve. Since it does it under hard acceleration, I might guess the map sensor.
