Lol..
Originally Posted by Area47
(Post 5027483)
there is a difference between can't and won't. same thing with the ecm flash.
I'm going to take a wild stab, that the BCM is somehow messing with the PCM, like not working together, somehow. I know guys have taken these crate engines and put them in older muscle cars without too much trouble. Just a thought, although an interesting project.
BCM has no influence on pcm driveability functions. It needs to be left with someone who has time to really start tinkering with it to figure it out. This is going to be one of those projects that you simply can't charge for all the time you spend on it shes going to be a lot of off the clock cause I want to figure it out time. I hate these the most but love em when I finally figure them out.
KOEO fuel pressure should be 55-76lbs
If it hasn't been done I would put a LSA fuel pump in it and flash the fuel pump control module for a LSA camaro. Flashing the FPCM may or may not do a damm thing but there are engine specific calibrations for fuel pump operation under varying conditions that can be causing the problem. Or scrap the FPCM and go to a boost referenced dual fuel pump aftermarket setup. |
Originally Posted by 01WS6/tamu
(Post 5027644)
I guess the only things changed in the wiring to accept the new engine were the two additional MAP sensors, switching from 5 pin to 3 pin cam sensor, and other provisions for the bypass valve solenoid control. Aside from those things, it should operate exactly like stock. Its just so hard to imagine what might be causing problems when literally everything has checked out good so far. |
Here's a video of the throttle going full retard. You'll notice with the key on, the throttle is relaxed at 31%. As soon as the pedal is touched, it snaps back closed to 16% and then proceeds to follow what the pedal tells it to do. After letting off of the throttle, it stays at 16% for a little while and then goes back to 31%. :shrug:
GDS dealership reflash to a CTS-V operating system and it won't start. VIN matched, VATS removed...no crank. I did notice the ECM/PCM segments are different between the Colorado and CTS-V stuff...could that be the issue with the GDS reflash?
Originally Posted by Atomic
(Post 5026365)
hey, as long as the logs look good... :lol:
| All times are GMT -5. The time now is 01:11 AM. |
