-   Tuning, Diagnostics, Electronics, and Wiring (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/)
-   -   Wiring the LM7 for AEM - sensor questions (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/wiring-lm7-aem-sensor-questions-504873/)
celicaxx Jul 17, 2012 07:09 AM
I'll be wiring from scratch the whole harness, so there won't be many things from the stock harness that I'll need.
What I have:
LS1 throttlebody
80lb injectors (bosch clips I believe)
Fuel from two pumps (A1000 and Walbro 255)
IAT will be a standard GM model
What I have on the list for wiring:
injectors
IAT
TB: Idle air and TPS
knock
fuel pump relay
coolant temp
coilpacks
What I'm not sure about is crank and cam sensor locations. Also, I'm sure I've forgotten something; it's early in the morning.
I haven't started yet, so I thought I'd get some input from you guys since this my first V8 swap. This is also my first AEM; installed megasquirt on my other cars.
Thanks,
Donnie
