-   Tuning, Diagnostics, Electronics, and Wiring (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/)
-   -   Wideband/cable for EFI Live (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/wideband-cable-efi-live-522521/)
Byrdman11 Oct 5, 2013 01:55 PM
I got the V2 EFI Live Flashscan/tuner. Im want the hook up a wideband to the DB9 female cable EFI sent. I want some easier to hookup than my PLX wideband. Plug and play would be awesome.
BLK02WS6 Oct 6, 2013 07:10 PM
I used to get cables from TAQuickness, but don't know if he is back in production - was backed up because of supplies for awhile. Just google TAQuickness and you will find his site...
Byrdman11 Oct 6, 2013 08:39 PM
Dammit store is closed... What do you use for hooking up your/a wideband???
Steve-O-08 Oct 6, 2013 09:07 PM
I use an LC-1 in my Silverado and another LC-1 with a plug in harness that I made if I need to do another vehicle. Works great with my TAQuickness cable.
Byrdman11 Oct 6, 2013 09:22 PM
What do I need LC1 and?? pics??
03klugss Oct 7, 2013 09:36 AM
I assume we are talking about you connecting your wideband thru Efi Live the serial way instead of analog correct?
Serial is MUCH better and accurate!
Byrdman11 Oct 7, 2013 11:18 AM
Yes, that is right. I'm wanting to log it.
03klugss Oct 7, 2013 11:31 AM
Well for me I use the LM1 and all I had to get was a null modem adapter that connected the LM1 serial cable to the efi live serial cable then set it up for serial wideband in efi live which is very easy and that's it.
03klugss Oct 7, 2013 11:39 AM
Sorry I'm not familiar really with the LC1 or I would try and help you out more.
BLK02WS6 Oct 7, 2013 06:42 PM
The only way may be to buy the tool to make the cable ends and do it yourself - the end that goes to the EFILive V2 is a male RS-232. The end for your wideband depends on the brand, but your instructions should have wiring diagrams. You may be able to find an IT person that makes network cables to help you make it...
