-   Tuning, Diagnostics, Electronics, and Wiring (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/)
-   -   Which wideband? (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/wideband-414060/)
WFOsierra Mar 16, 2008 11:22 PM
Which wideband?
I just installed my HSW nozzle kit, I wanna run an accurate wideband afr guage. I am not gonna be running it with any tuners, I just want one to monitor my afr while im spraying,
Is there one made thats plug and play into the factory O2 sensor plug?..or am i gonna have to splice into the wires?..
I am not gonna be logging any data from the wideband just gonna use to to watch my afr while spraying...
Derek @ EDO Mar 16, 2008 11:24 PM
I love my PLX unit!
WFOsierra Mar 16, 2008 11:43 PM
is it a plug and play unit?..software?...tell me about the plx unit. I want something to connect right in without any wiring except for like the power and stuff for the guage.
Derek @ EDO Mar 16, 2008 11:47 PM
Its as easy as screwing in an 02 sensor hooking up a gauge and power. There are many guys on here running PLX setups.
Derek @ EDO Mar 16, 2008 11:48 PM
http://www.plxdevices.com/products/dm5/afrsmcombo/
check it out, you can also download the product brochure off the site.
WFOsierra Mar 16, 2008 11:49 PM
what do you do about the sensore wires running upto the ecm...does this t into the factory wiring ? or do you have to have a seperate bung for the plx o2 sensor?
Low_LSX Mar 16, 2008 11:49 PM
Do you still offer the $225 deal?
Derek @ EDO Mar 16, 2008 11:56 PM
You can install these two ways.
The easiest is adding another 02 bung. Any exhaust shop can do that!
PLX also has instructions on how to emulate your stock narrowband voltage where your pcm will think that the stock narrowband is still in place.
This way is not difficult either but it does involve cutting a wire or two.
Either way will work just fine!
WFOsierra Mar 17, 2008 09:53 AM
what about the obd2 afr guage plx has?
shakesvho Mar 17, 2008 10:26 AM
..............plx.....................
