Who adjusts thier tune for the 10% or up to 10% ethanol at the pump these days...
Old Jul 27, 2010 | 09:35 PM
  #21
00ChevyScott's Avatar
Wearin' da big hat
Sounds like a waste of time to me... Trying to squeeze that extra 3 rwhp out of that 4.8 Corey? Lol
  #22
KLUG'S SS's Avatar
FormerVendor
Originally Posted by Avalanche2002
Holy crap, man, you're more **** than I am!
It's a disease.
But on a serious note Ford is starting to recognize where we are heading with these ethanol blended fuels as they are starting to have some of their factory calibrations setup already for E10, I will have to double check a tune file but I believe for one if I am not mistaken the new mustangs are set to 14.1 afr
Old Jul 27, 2010 | 09:38 PM
  #23
dc_justin's Avatar
Hello Dave
He won't see any power out of it, just better consistency every time he goes and re-tunes it. As it is right now, all of his wideband time results in a VE table that is at least 4-5% higher than actual, which then affects the PCMs spark reference, torque calculation, etc, etc.
Old Jul 27, 2010 | 09:42 PM
  #24
Wearin' da big hat
So quicker (hardly noticeable) fuel corrections and throttle response? Smoother throttle transitions?
Old Jul 27, 2010 | 09:44 PM
  #25
dc_justin's Avatar
Hello Dave
Initially.
In a completely closed loop vehicle, 14.68 would yield trims in the 4-5% range assuming all else is perfect with E10. Specifying 14.1x would yield trims very close to 0.
Old Jul 27, 2010 | 09:50 PM
  #26
Atomic's Avatar
I have a gauge for that
I have found stoich for fuel in my area to be around 14.4 which would indicate around 5% eth. I found this by comparing trims to AFR error in steady state type conditions.
Old Jul 27, 2010 | 10:00 PM
  #27
BlackGMC's Avatar
Resident Retard
don't be mad that you have had EFI Live for 1+ years and you still have no idea how to use it.
But this does answer some of my questions about the side affect/ wierd issues i have seen after retuning my truck 2 weeks ago... I like messing around with tuning, so if i have time this weekend i am going to check out the differences.
Old Jul 28, 2010 | 09:32 AM
  #28
fastrt's Avatar
11 Second Truck Club
so for 5-7% blend in my area, a 14.4ish would bring trims close to 0? and a true E10 would be 14.17 right. so my question is how much of a diff is it to tune for 14.68 vs 14.4?
Old Jul 28, 2010 | 09:44 AM
  #29
BlackGMC's Avatar
Resident Retard
from my understanding is that would affect your airmass calcs. for example: you would be referencing the wrong value in your spark table, thus your commanded spark value would be a little off... Also your IDC would be up a little bit too.
But i have a question. is E85 and E10 similar? Meaning E85 contains 85% ethanol, and E10 contains 10% ethanol? Or am i way off... if i am not does that mean if the airmass was correct would we be able to get away with a little more spark due to the higher octane rating of ethanol? Or do i have things completely wrong???
Old Jul 28, 2010 | 09:45 AM
  #30
lownslo's Avatar
ha run the timing up until it knocks and pull it back just a hair
