when is it a good time ???
Old Feb 25, 2013 | 06:00 PM
D.J Vasquez's Avatar
Default when is it a good time ???
wanted to know when should i change my mass air sensor ?? the truck has 135000 !! with lots of mods!!
custom grind 227/230 - 110 . 612'' lift comp cam,pac racing double springs 130#seat,337#opean,titanium retainers,cylinder heads are 2011-799 casting low miles,milled .035'',3 angle valve job,deburred ,and polished, comp cams gold roller rockers , spectre cold air intake ,coustom tune by {carolina auto master}tci,2200 stall converter 4l60e,rebuilt tranni with all racing bands and clutches ,airaid throttle spacer, pacesetters long tube headers /Y-PIPE,no cats, moroso oil catch can ! witch really works great !!!more later !!
Last edited by 03sierraslt; Feb 25, 2013 at 06:09 PM. Reason: Moved to the correct section
Old Feb 25, 2013 | 06:03 PM
TIM Z's Avatar
11 sec. Truck Mod
When your throttle body spacer gets broke in .
Old Feb 25, 2013 | 06:11 PM
03sierraslt's Avatar
I wouldnt change it unless there was a reason, you can clean it with Mass airflow sensor cleaner.
Old Feb 25, 2013 | 06:24 PM
yeah !i did clean it off about a month ago !! i really didnt know the life span on one !! thanks guys !!
Old Feb 25, 2013 | 06:26 PM
TIM Z's Avatar
11 sec. Truck Mod
Electrical contact cleaner works great also , try not to run an oiled filter , they are bad for MAFs.
Old Mar 3, 2013 | 02:27 AM
kogelch's Avatar
If you have a tuner, log the data for the maf to determine if its operating properly.
Old Mar 3, 2013 | 11:33 AM
dmelvin's Avatar
You'll throw a P0101 code when it goes bad and/or is so dirty that it's malfunctioning. I usually clean mine once a year.
Also.
I ed at this
chevyl33
Aug 24, 2015 08:21 AM
silver-mod-o
Jul 27, 2015 05:24 PM
maxspeed05V
Jul 19, 2015 07:08 PM
GMCtrk
Jul 17, 2015 06:39 PM
