what is your misfire set at?
I had p0300 code and had it tune out looks like they maxed all the tables. Is this ok I thought I read somewhere that maxing them was bad?
it depends on ur timing tables, AND fuel trim. if duty cycle is over 80% on injectors, it WILL be bad
Mine is something very high (can't remember the number). Why would you say maxing this is bad if your IDC is close to 100%.
If your fueling (AFR), timing and such is dialed in, I don't see how this can be detrimental especially if you log on a regular basis. Am I wrong here? |
Oh yea to answer your question :) Depending on your setup? Most trucks didnt need any ajustment, But the ones that did, I just multiplyed the idle regions 2-8% just depends...
would it be a good idea to copy stock misfire back in and start by multiplying the numbers until no misfire is detected? I only had light coming on every once in a while. Tuner disable the p0300 code but i looked at my misfire tables and they are maxed . |
