What could it be? Flashing check engine w/o dtc
Well my truck recently started to get a Check engine Flashing light... ive been told its a misfire thing.. but the wierd thing is that the guy at the shop doesnt get no codes... he checked sparkplugs and wires ect.. he says their good.. i would think it could be a clogged injector... the truck sounds like it has a baby cam but it doesnt LOL any advice what could it be... ive been told it could be the crank sensor...The truck runs fine too.. but havent tried WOT.. i think my best bet is to take it to my tuner and check for DTC running it.. with HP tuners.. ??
Mine did the exact same thing your talking about. Turned out the bolts in the head had loosened up after the header install. All that extra air going out through the exhaust fooled the pcm into thinking it was lean. So it added more fuel and was pig rich! It idled ok, but choppy, and bogged like hell when ya out your foot into it. It was also throwing random misfire codes.
Yep, should be a p0300 multiple random misfire. Stock cam and stock torque converter? A scan with HPT should tell you everything you need to know.
Originally Posted by smoggist
(Post 4900050)
Originally Posted by Atomic
(Post 4900051)
Originally Posted by NLalexx
(Post 4900054)
yhea well this started today after i got my built tranny i had a TB stall but now i have a TBSS stall its smaller but the guy said they are better in topend bla bla
Give him one more chance at figuring this problem out. After that you need to find a better mechanic... I'm already hearing things that sound like red flags, IMHO. |
Originally Posted by AKlowriderZ71
(Post 4900059)
:bs:
Tabueno Alex, ya duermete. Manana a la escuela :)
Originally Posted by Crisdg.KHP
(Post 4900061)
I'd check crank sensor as well. When we did my trans we pulled the starter and ripped a wire out on ky crank sensor. But mine would even start. Maybe yours got bumped
