tuner help please
Old May 20, 2006 | 06:39 PM
jjpea's Avatar
Default tuner help please
i just put the supermaxx system from dynatech on my 01 tahoe, 5.3. gas mileage has greatly dropped, idle is good, performance seems better. i'm pretty sure that i should have done a tune on it as soon as i put the system on. my local dyno wants 600 cold for a tune, one pull before the adjustments, then one pull after. 600 to me is alot for this, would i be better off getting my own tuner, (handheld or computer) and doing my own tunes? plus, it would be used more than once, unlike the dyno. i know that the dyno will show true results for hp and torque, i'm just worried about the air/fuel mix or dropping a piston and such. plus, in the next couple of months i plan on doing more to the hoe, so that means more adjustments. help please, my exhaust tip is starting to turn black.
Old May 20, 2006 | 07:55 PM
RoninsDenali's Avatar
Spending 600$ for a dyno tune is nuts... To be honest, you would be better spending that money on HPTuners or EFILive. Avoid the handheld tuners if at all possible, and my personal vote goes to HPTuners which can be nabbed for only 499$ for standard or 649$ for the pro package.
Grated it is still a lot of money, but i believe its one of the best investments that can be made especially if you like to tinker with your motor
Old May 20, 2006 | 09:04 PM
thunder550's Avatar
High on diesel fumes
Yep for $600 you might as well get your own software, especially if you plan on doing more mods that will require additional tuning tweaks.
Old May 21, 2006 | 09:42 PM
oxidizr's Avatar
Moderator / Sponsor
Where are you located? I can help you in if your in the southern California area.
Old May 21, 2006 | 09:50 PM
jjpea's Avatar
Default thanks anyway
north dakota, how bout you just drive on up! thanks again
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Chevy305
Sep 28, 2015 09:21 PM
Raiderjim
Sep 28, 2015 10:37 AM
bisqikss
Sep 27, 2015 09:40 PM
sTNT971
Sep 26, 2015 04:22 PM
