trans wiring help
Old Dec 14, 2012 | 09:23 PM
greasemykey's Avatar
Default trans wiring help
so a few months ago i bought a "uncut" wiring harness from a member that was missing both connections that go to the neutral saftey switch. i went to the junk yard and bought the plugs i needed and noticed that there are 2 green wires 2 yellow wires and to black/white wires on each side. does it matter how they are wired? how can i tell them apart? any help here would be awesome.
Old Dec 18, 2012 | 09:24 PM
bump. PLEASE IM DESPERATE. my hanes manual sucks and doesnt give me pin numbers on the wires go to on the pcm.
Old Dec 18, 2012 | 10:13 PM
Ferocity02's Avatar
These might help.
Old Dec 18, 2012 | 10:34 PM
it is a start thanks. but where do the wires go? they cut the wires and there are 2 yellow and 2 black/white they are the ones i need to make sure i wire correctly.
Old Dec 18, 2012 | 11:04 PM
Ferocity02's Avatar
Try finding a pinout diagram for your harness/PCM, then use a multimeter on the continuity setting to match the wire at the trans to the wire at the PCM.
Old Dec 18, 2012 | 11:29 PM
my haynes manual doesnt have one and i have looked online but no luck. i may try the dealer and see if they will throw me a bro hook.
Old Dec 18, 2012 | 11:45 PM
Ferocity02's Avatar
https://www.performancetrucks.net/fo...1/#post3695063
Old Dec 18, 2012 | 11:53 PM
Ferocity02's Avatar
I suggest you double check, but it looks like black/white from range switch goes to blue 32.
black/white from pnp switch goes to blue 40.
yellow from range switch goes to blue 72.
yellow from pnp switch goes to... not sure.
The yellow from the pnp can be found going into the fuse box under the hood. I suspect it might not go to the PCM. See my post here. This is wiring on my '01 5.3L, you're might be different, but you sig says 2000 so it should be the similar.
Old Dec 19, 2012 | 07:13 AM
thanks. im going to OHM out the wires today and get them soldered in so i can finish my harness install.
Old Dec 19, 2012 | 07:38 AM
TXSZ66AVLANCHE's Avatar
Are you doing a LS swap into an older vehicle? If you are, you don't need the range sensor.
