Is there a way to view the delta between the MAF and the VE Table ??
Old Jul 25, 2006 | 05:26 PM
Yelo's Avatar
Default Is there a way to view the delta between the MAF and the VE Table ??
Assuming one is running a MAF tune is there a way to see in percentage points how much difference there is between the MAF and the VE tables fueling calculations...kind of like the AFR error pid, but MAF error instead. I know the fuel trims will give you VE error, but that's not what I'm looking for....
Old Jul 25, 2006 | 05:37 PM
dc_justin's Avatar
Hello Dave
You could set up some sort of a PID that calculates the % difference of GM.DYNCYLAIR_DMA (Air Flow Grams/Cyl - Speed Density)
and your airmass derived from the MAF flow rate.
Old Jul 25, 2006 | 05:42 PM
Yelo's Avatar
Can you explain exactly how to do this (I haven't had to set up a custom PID yet)...
Let me explain why I want this: I'm trying to find a way to cheat when tuning VE at WOT, if I can get % difference between MAF and VE I can calculate VE at WOT without having a wideband (this is assuming that the MAF is calibrated correctly of course). while I'm not sure this is the method I'd use on my own truck (I have a wideband on order) it WOULD be useful on other trucks that I tune that do not have widebands
Old Jul 25, 2006 | 05:43 PM
dc_justin's Avatar
Hello Dave
I can with EFI Live, But not HPT, sorry...
Old Jul 25, 2006 | 09:26 PM
Yelo's Avatar
The PID is: [PID.16]-[PID2320] and output in % to get the difference between the VE and the MAF. Many thanks to RedHardSupra for figuring this out
Vortec350ss
Jan 12, 2016 10:36 PM
legerwn
56
Nov 15, 2015 10:21 PM
Tydriver
45
Oct 23, 2015 09:19 PM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
