Stock Yukon lean??
Old Oct 26, 2008 | 01:25 PM
nonnieselman's Avatar
Default Stock Yukon lean??
Hey guys, im kinda confused... :shock:
workin with a bone stock 2005 Yukon 5.3 70k miles..
SES light was on so i read the codes.
P0171 "Fuel Trim System Lean Bank 1" EPA
P0174 "Fuel Trim System Lean Bank 2" EPA
P0171 "Fuel Trim System Lean Bank 1" MH
P0174 "Fuel Trim System Lean Bank 2" MH
U1500 "Inter-device Dedicated Bus" HC
B3770 "Air Flow Control 6 (A/C) Feedback Circuit" H
B0414 "Temperature Control {single or 1} (main or front) Feedback Circuit Range/Performance" H
B0229 "Recirculate Position Feedback Circuit Range/Performance" HC
B3764 "Air Flow Control 4 (blend face and floor) Feedback Circuit" H
B0429 "Temperature Control 3 (rear) Circuit Range/Performance" H
B0434 "Temperature Control 3 (rear) Feedback Circuit Range/Performance"
C0750 "Left Front Low Tire Pressure Sensor" H
C0755 "Right Front Low Tire Pressure Sensor" H
There are the codes..
So i decided to log it idling..
Lemme know what yall think or suggest something.. haha
The truck was stumbling at idle every now and again and would die on occasion.
thanks guys!! Ill be subscribed to this and be getting the notifcations on my cell phone.
So any help is appreciated greatly!!
-Jonathan
Old Oct 26, 2008 | 01:50 PM
woops... here is the Log...
File Type: efi
Old Oct 29, 2008 | 10:00 AM
built408's Avatar
Does it run bad on cold mornings? It's probably the intake gaskets leaking, they had some problems with those.
Old Oct 29, 2008 | 04:46 PM
Ill ask and see what she says.
It studders at idle some.. I need to check the fuel pressure too.
Oobray
Jun 13, 2022 03:38 AM
5.3Caprice
Nov 7, 2015 08:56 PM
kr1s
Aug 24, 2015 05:34 PM
05GMC4.8
Aug 7, 2015 09:55 PM
signguy62
Jul 16, 2015 05:43 PM
