slight squeaking from engine at idle?
I can hear a slight squeaking noise coming from the engine bay when my trucks idling, especially on a cold start. I just noticed it about a month ago. I remember reading once that someone had this problem and it was the rocker arms not getting enough oil? How can I fix this squeak, is it bad at all? Thanks guys, I just want to hear the low drone from my exhaust only when the engines running, not a high-pitched squeak added in the background :shrug:
You check the belt and pullies?
belt is very snug, it's not a loud squeak like a belt, it's more of a slight background squeak. if someone who didn't know a damn thing about cars listened to it, they prob wouldn't even notice the squeak
Ahhhh, mine was doing something similar about a week before one of my comp 918's broke. Not sure if my noise had anything to do with it though.
damn that sucks, do you know what caused the spring to break? all i know is the noise is coming from the front of the truck, i'm not even sure if its' the engine
Pull the belts and see if it still squeaks. If it does my guess is its got a cam going flat. The LS engines seem to feed on cams about as bad as the old carbed 305s did.
I had the squeak. Changed the idler pulley, still had the squeak. Change the alternator all together (l/t warranty), and it finally came down to the a/c tensioner pulley. I changed that and the belt, no more squeak. Amen!
Roller on a lifter chewed up and cam lobe damaged. Just did one last week under warranty.
Originally Posted by scooter k
(Post 4836267)
Originally Posted by Holty
(Post 4844364)
Scooter, how did you diagnose that? I'm sure someone didn't come in with the slightest little squeek and the first thing you guys did was replace the cam and removed heads to replace the lifters.
| All times are GMT -5. The time now is 09:16 AM. |
