Running Lean
Okay guys, I'm cruising @ 70mph, let off the throttle(coasting) and the wideband goes lean. But while doing so the truck jerks like as if its starving for fuel. If I just barely touch the throttle, it stops jerking. Would the the throttle cracker, follower or idle running air flow take care of this?? I know that fuel needs to be taken away when letting off the throttle but i shouldn't do this. It just started doing this a few moths ago. Also it gets worse when going down a hill.
Thanks James |
Sure its not DFCO?
Never thought of that........but could be it. What disable it??
James |
Well not disable it but play with the ramp rate or hold time???
James |
I would just turn it off completely at first to make sure that is it...then if it is you can play with the entry and exit settings
Ok, to turn it off just zero out everything??? I'm new with the DFCO table.
James |
The hold time is 0.000, entry ramp rate is 0.050 and the exit ramp rate is 0.013
James |
Its probably because you dont answer your phone when people call :poke:
Just set the enable temp to 250 or something higher than you will reach.
Originally Posted by closet red neck
(Post 4623620)
James James |
| All times are GMT -5. The time now is 03:59 AM. |
