rough idle!!!
Old Mar 22, 2012 | 06:45 AM
JT8604's Avatar
Default rough idle!!!
94 tbi bone stock. When i crank up truck runs rough as hell, sounds like i have a hellacious cam!, makes a little black smoke and smells like raw fuel. Then after about 8-10 seconds of that truck will idle up to 1500 rpms or so, then, idle back down to 800-900 rpms The truck runs good after that minus the high idle. Has anyone else experienced something similar to this? Ive put new spark plugs, wires, cap, rotor, fuel filter, air filter, trying to correct this problem. Thanks in advance for any advice you may have!
Old Mar 22, 2012 | 12:29 PM
cttandy's Avatar
Have you tried replacing the ignition module in the distributor?
Old Mar 22, 2012 | 12:47 PM
JT8604's Avatar
No, I havent tried that. Listening to the motor now that I think of it it kinda sounds like I have a vacuum leak somewhere. I'm going to look further into it and inspect for leaks.
Old Mar 23, 2012 | 09:47 AM
JT8604's Avatar
Found it, had a vacuum leak at the intake, and cleaned the map sensor and it fixed it. Thanks for the suggestion.
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
BlownHD
Oct 3, 2015 12:24 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Pimpinpete
Sep 8, 2015 07:39 PM
