Quick question...hopefully
I am installing my procharger along with injectors and my nelson tuned pcm. My question is, if I install the injectors and the pcm, would I be able to move the truck around the garage/yard and slow speeds? I would think it would be ok since I would not be into boost at that low of an rpm anyways, or I wouldn't think I would. If not, thats fine too.
Yes, you should be fine to drive it with the new injectors and the tune. He should have ajusted the tune for the injectors and then just increases the PE table to richen it up when boosting and pull some timing from the top end.
Thats what I figured, just thought I would ask.
