Problem with Racetronix fuel pump harness...
Got the 450 in, turned the key and nothing. No prime. Checked the connector at the assembly and sure enough the power and ground leads were switched. Got that fixed, turned key and it runs only to find out the gas gauge doesn't work. Unplug Racetronix harness. Plug stock back in and sure enough gas gauge works. Any ideas? Anyone encountered this before? If the power and ground were switched makes me wonder what else...Thanks
check this out.......guy just posted this lastnite on HPJ
Racetronix smokes too much pot - HorsepowerJunkies.com Forums
Just drove the truck 5 miles and it died on the highway.
Towed it home, pulled fuel filter and turned key on, can hear the FP priming but there's no fuel output. There's half a tank of gas in there. I'm guessing the hose popped off at the bulkhead connection since I didn't have room to get a clamp in there. I just dont see how though, it's a plastic tube that is very snug over the barb. Stock uses no clamps. So much fail with all this.
slowlsx
Aug 13, 2015 08:28 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
