Possible Tune Problem
Old Apr 13, 2007 | 02:04 PM
LesPaul's Avatar
Default Possible Tune Problem
Hey guys, I normally don't post in here because i don't tune my own truck... but after i swapped out my trans and got a new tune for it, its been acting up.... The problem only happens when i go WOT at 30 or so... it hits the limiter just before shifting, however it doesn't do this at WOT from a stop... Do you think this is the tune or a drive line issue??
Thanks
LES
Old Apr 13, 2007 | 02:22 PM
Nick™'s Avatar
and you're running a new FLT in your truck? that's usually what I notice when a tranny is fixing to go. It's possible that your rev limiters and shift points need to be spaced a little bit more.
Old Apr 13, 2007 | 02:25 PM
LesPaul's Avatar
yeah The FLT has less than 1000 miles on it...The trans is solid... truck performs perfectly under all other circumstances only wot at 30 is an issue... should i go get a quick video????
Old Apr 13, 2007 | 02:32 PM
silver-mod-o's Avatar
Hunt&Fisherator
mine's been doing the same thing... just chill on the hard punches from a roll... rolling into the throttle in 1st and letting it shift into 2nd on its own, it wont do that. I believe my problem is in the tune also..
Old Apr 13, 2007 | 02:34 PM
LesPaul's Avatar
kinda seems like the limiter is to close the shift point... seems like a bump in the limiter would fix the problem
Old Apr 14, 2007 | 06:36 PM
gmforlife's Avatar
I had a problem kinda similar with my stock setup, i had accidentally changed the full throttle shift speeds too high, when you do that, if you change the 2>1 too high, it will hit the rev limiter before it shifts, you have to lower the speed
ferrellrooster
Mar 6, 2025 03:22 PM
mr03silverado
Jun 26, 2016 06:05 AM
shawn96gmc
May 17, 2016 04:15 PM
pittman
Jan 19, 2016 07:06 AM
lxcoupe
Jul 14, 2015 10:14 PM
