p0506
Old 04-04-2018, 05:05 PM
Registered User
IsaacT's Avatar
Default p0506
My 2012 GMC 2500 stalls sometimes in idle and code p0506 is stored, does anyone know the problem?
Old 04-04-2018, 05:21 PM
FFDP's Avatar
Here are some common things.
  • Defective/sticking Idle Air Control Motor
  • Intake Manifold Vacuum leaks
  • Carbon buildup in the Throttle Body
Clean the MAF and throttle body first, check for vacuum leak and see what happens. If the problem stays I'd be looking at a faulty throttle body itself. The motor may be weak or faulty and won't allow it to idle properly.
Old 04-04-2018, 05:40 PM
Registered User
IsaacT's Avatar
I changed the throttle body and checked for vacuum leaks
Old 04-04-2018, 05:45 PM
FFDP's Avatar
Did you perform a throttle relearn with a scan tool when you replaced it?
Old 04-04-2018, 05:55 PM
Registered User
IsaacT's Avatar
yes I did
Old 04-04-2018, 06:00 PM
FFDP's Avatar
I'm out of idea's without me standing infront of the truck with a my laptop to see what is going on.
The throttle body and intake leaks are the most common issues with a faulty computer being the last problem I'd be looking at. If shot gunning a new AC Delco throttle body didn't help then I have no idea right now. Maybe bring it to a dealership.
IsaacT
03-21-2018 07:26 PM
Quick Reply: p0506
