-   Tuning, Diagnostics, Electronics, and Wiring (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/)
-   -   P0449? (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/p0449-405762/)
X-running Nov 23, 2007 10:35 AM
P0449?
Does anybody know what causes this? 06 Tahoe 4.8
CHEVRACER83 Nov 23, 2007 10:49 AM
DTC P0449
Circuit Description
A battery positive is supplied to the evaporative emission (EVAP) canister vent solenoid valve. The control module grounds the EVAP canister vent solenoid valve control circuit to close the valve by means of an internal switch called a driver. The scan tool displays the commanded state of the EVAP canister vent solenoid valve as ON or OFF. The control module monitors the status of the driver. If the control module detects an incorrect voltage for the commanded state of the driver, this DTC sets.
The following table illustrates the relationship between the ON and OFF states, and the OPEN or CLOSED states of the EVAP canister vent solenoid valve.
Control Module Command
EVAP Canister Vent Solenoid Valve Position
ON
CLOSED
OFF
OPEN
DTC Descriptor
This diagnostic procedure supports the following DTC:
DTC P0449 Evaporative Emission (EVAP) vent Solenoid Control Circuit
Conditions for Running the DTC
• The engine speed is more than 400 RPM.
• The system voltage is between 10-18 volts.
• DTC P0449 runs continuously once the above conditions are met.
Conditions for Setting the DTC
• The control module detects that the commanded state of the driver and the actual state of the control circuit do not match.
• The above conditions are present for a minimum of 5 seconds.
Action Taken When the DTC Sets
The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
• The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
• A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
• A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
• Clear the MIL and the DTC with a scan tool.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
Listen for a click when the valve operates. Verify that both the ON and the OFF states are commanded.
This step verifies that the control module is providing ground to the EVAP canister vent solenoid valve.
This step tests if the EVAP canister vent solenoid valve control circuit is grounded.
Step
Action
Yes
No
Schematic Reference: Engine Controls Schematics
Connector End View Reference: Engine Controls Connector End Views or Powertrain Control Module (PCM) Connector End Views
Did you perform the Diagnostic System Check - Vehicle?
Go to Step 2
Go to Diagnostic System Check - Vehicle
Turn ON the ignition, with the engine OFF.
Command the evaporative emission (EVAP) canister vent solenoid valve ON and OFF with the scan tool.
Do you hear or feel a click from the EVAP canister vent solenoid valve when the valve is commanded ON and OFF?
Go to Step 3
Go to Step 4
Observe the Freeze Frame/Failure Records for this DTC.
Turn OFF the ignition for 30 seconds.
Operate the vehicle within the Conditions for Running the DTC. You may also operate the vehicle within the conditions that you observed from the Freeze Frame/Failure Records.
Did the DTC fail this ignition?
Go to Step 4
Go to Testing for Intermittent Conditions and Poor Connections
Turn OFF the ignition.
Disconnect the EVAP canister vent solenoid valve.
Probe the batter positive voltage circuit of the EVAP canister vent solenoid valve with a test lamp connected to a good ground. Refer to Troubleshooting with a Test Lamp .
Does the test lamp illuminate?
Go to Step 5
Go to Step 11
Connect a test lamp between the control circuit of the EVAP canister vent solenoid valve and battery positive voltage circuit of the EVAP canister vent solenoid valve at the EVAP canister vent solenoid valve harness connector.
Command the EVAP canister vent solenoid valve ON and OFF with a scan tool.
Does the test lamp turn ON and OFF with each command?
Go to Step 9
Go to Step 6
Does the test lamp remain illuminated with each command?
Go to Step 8
Go to Step 7
Test the control circuit of the EVAP canister vent solenoid valve for a short to voltage or an open. Refer to Circuit Testing and Wiring Repairs .
Did you find and correct the condition?
Go to Step 14
Go to Step 10
Test the control circuit of the EVAP canister vent solenoid valve for a short to ground. Refer to Circuit Testing and Wiring Repairs .
Go to Step 14
Go to Step 10
Inspect for poor connections at the harness connector of the EVAP canister vent solenoid valve. Refer to Testing for Intermittent Conditions and Poor Connections and Wiring Repairs .
Go to Step 14
Go to Step 12
Inspect for poor connections at the harness connector of the control module. Refer to Testing for Intermittent Conditions and Poor Connections and Wiring Repairs .
Go to Step 14
Go to Step 13
11
Important: If the fuse is open, inspect all related circuits for a short to ground.
Repair the open or short to ground in the battery positive voltage circuit. Refer to Wiring Repairs .
Did you complete the repair?
Go to Step 14
Replace the EVAP canister vent solenoid valve. Refer to Evaporative Emission (EVAP) Canister Vent Solenoid Valve Replacement .
Did you complete the replacement?
Go to Step 14
13
Replace the powertrain control module (PCM). Refer to Control Module References for replacement, setup, and programming.
Go to Step 14
14
Go to Step 2
Go to Step 15
Observe the Capture Info with a scan tool.
Are there any DTCs that have not been diagnosed?
Go to Diagnostic Trouble Code (DTC) List - Vehicle
System OK
X-running Nov 24, 2007 08:44 AM
Thanks this really helped out.
CHEVRACER83 Nov 24, 2007 12:34 PM
no problem brother.... did it get you fixed?? or are you still diagnosing it??
barmann88 Dec 24, 2007 09:43 AM
Got the same code, so hopefully i can figure it out and post my expierence :engarde: The funny thing is i cleared it out with hp tuners and by the time i backed out of the driveway it was already back on LOL :devil:
04BlackGmc Dec 24, 2007 06:57 PM
just blow it up brett.
UBLUZIN03 Dec 24, 2007 10:10 PM
i had the same code...just replace the evap vent solenoid.
barmann88 Dec 26, 2007 08:02 AM
When the bottle gets put on she just may blow :devil:
barmann88 Dec 26, 2007 08:03 AM
is the soenoid in the back, by the spare tire?
UBLUZIN03 Dec 26, 2007 09:58 AM
no, its by the gas tank..kindo on top of it. its a real pain in the ass but you can remove w/o removing the tank or bed.
