-   Tuning, Diagnostics, Electronics, and Wiring (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/)
-   -   P0446?? (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/p0446-354572/)
jchorner99 Dec 13, 2005 08:51 PM
P0446??
P0446 - Evaporative Emission Control System Vent Control Circuit Malfunction.
showed up as a trouble code a pending code and a freeze code.
checked the gas cap, on tight.. o ring looks fine. any ideas?
budhayes3 Dec 13, 2005 09:44 PM
Make sure that all of the hoses to the charcoal canister, fuel tank, etc. are properly installed and fully seated, also make sure that none are bent or kinked...a few different things could give that code...bad EVAP vent valve, fuel tank pressure sensor, even a bad charcoal canister (sometimes they break down internally and the pieces clog up ports)
jchorner99 Dec 13, 2005 11:10 PM
could this have anything to do with the fact that I just installed my Nelson tuned 02' PCM @ 50 miles ago?
budhayes3 Dec 14, 2005 09:28 PM
That shouldn't have anything to do with it, unless there was an internal PCM problem. Anything's possible, but I doubt that the new PCM is at fault. EVAP codes are pretty common with just about every manufacturer...I had a similar code on my wife's Matrix about 6 or so months ago, and was able to figure out that the charcoal cannister was flooded with fuel. I figured out that it was a result of a local gas station squeezing every last drop while trying to round up to the nearest dollar (New Jersey isn't self-serve). I cleared the code and have been lucky so far (knock on wood)
jchorner99 Dec 14, 2005 10:20 PM
cool, thanks man. I appreciate it. I'm going to check it all out friday. I'll post with findings :rock:
jchorner99 Dec 17, 2005 10:51 PM
code cleared it self on the drive home today.... I guess mabye it was over filled. Although I never top off.... good riddance........wtfe... thx man. i appreciate it.
2000Redstep Dec 18, 2005 03:05 PM
Had the same code with mine. The dealer cleaned the filler neck to tank connection, $45.00 labor.
budhayes3 Dec 18, 2005 09:53 PM
Cool deal, hope it stays "fixed" :cheers:
OneBadSSS Oct 17, 2007 10:08 AM
Got a SES light the other day :(
So my SES light came on the other day despite the fact that the truck's running strong and so I took it to Auto Bone to have then pull the code and P0446 x 2 is what I got. Any idea what kind of damage to my wallet I can expect when I take it into the stealership if none of the obvious things (loose connections, kinked hoses, etc.) are the culprit?
Shamrock84 Oct 18, 2007 09:23 PM
hey I had the same deal P0446 comin up twice on 2002 tahoe. i gas cap but it came back, if i remember correctly it was a bad evap vent solenoid that was failed to open, 50 $ new at dealer, replaced it and it was all good
