Open loop SD Tune Emissions Help.
Help trying to pass emissions test with turbo 6.0 using plx wideband not 02's On a Open loop Speed density Tune. Dono How evap was from factory or why its showing trouble. Need a direction to start.
i was pondering this myself but if all codes are off , they will pass readiness tests .
my question is for sd tuned , you have to keep your maf code at least the p0101 for your engine to go into sd settings . is there a way to have this not show up and still run so when they check dtc's it isnt there?
"For off road use only .
Found this googling around : "P0131-P0167 - Oxygen sensors P0400-P0430 - EGR, AIR, and catalysts P1133-P1156 - Oxygen sensors P1404-P1416 - EGR and AIR systems P1441-P1443 - Evaporative purge Set to "not reported" should show you what you want to see, at least with regards to the tests. Leave the MIL indicator enabled for all " , not my work and have to state again "OFF ROAD USE ONLY" ."
Follow this and it will clear all the system checks I was trying to clear.
I dono about that one either maybe someone else can help us. I will post it in my efi live support thread and see if I can get an answer for us.
