-   Tuning, Diagnostics, Electronics, and Wiring (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/)
-   -   P 0300 code (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/p-0300-code-519376/)
03 BLKTAHOE Jun 27, 2013 09:00 PM
P 0300 code
The run down... I just put an lq4 block with a turbo, comp cam xr265, #60 injectors in my truck. Its throwing a code p 0300 multiple misfire. I changed out the plugs, coil packs and spark plugs. The plugs are tr6 4177 gapped to 29. I did have it tuned on the previous 5.3 and turbo and was told that the tune would very close. Is it possible the tune?
06murder Jun 27, 2013 09:23 PM
Po300 is the pain in the ass code. Check to see if your intake has a leak.check make sure all 8 injectors are clicking. Fuel pressure test. Compression test...clean tb and maf also, that's all i can think of right now
BLK02WS6 Jun 28, 2013 02:03 PM
Did you have a cam in the 5.3?
03 BLKTAHOE Jun 28, 2013 02:47 PM
Man I hope it has nothing to do with compression that sounds to serious. I've cleaned the TB and the Maf im got to do a little research on how to do the other test.
03 BLKTAHOE Jun 28, 2013 02:48 PM
No just the 60# injectors and the turbo.
dbizzle Jun 28, 2013 02:51 PM
how much boost are you running? when i went from 6 to 10 i needed a smaller plug gap, could be as simple as making the gap smaller, at least this fixed my po300
BLK02WS6 Jun 28, 2013 07:52 PM
It very well could be the cam - it is common to need misfire tables tuned because they throw P0300 during low rpm with a cam. If it doesn't have any misfire codes coming in for specific cylinders, and it runs well with no apparent miss, that would be my guess...
Truckshop Jun 29, 2013 06:01 PM
It needs to be tuned for the setup. Also
Needs a crank relearn. After that your p0300 will be gone.
zx6rspeedfreak Jun 29, 2013 06:57 PM
I'm having kind of the same issue. When should the crank relearn be used
03 BLKTAHOE Jun 29, 2013 10:02 PM
Iv got a 9.4 pound spring in but since the motors been in ive been staying out of boost.
