-   Tuning, Diagnostics, Electronics, and Wiring (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/)
-   -   OBD 2 Scaner/Reader (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/obd-2-scaner-reader-560791/)
turboal1 Nov 7, 2023 06:04 PM
OBD 2 Scaner/Reader
what's a good OBD-2 Hand scanner, 2010 Chevy E67 PCM, for a decent price,
i see a load of diff ones on e-bay, I'am NOT familiar with all of them. good or bad
RB04Av Nov 7, 2023 09:54 PM
What do you want to "scan"?
An Android phone, a ELM327 adapter, and Torque Pro, will "scan" just fine. A bit $$$$$$ though... the ELM327 might cost $20 or so, and Torque Pro is $4.99. Butt if you REALLY want to bite off, time to put on your big boy underpants and STEP UP, and lay out all that long green.
Iff on the other hand you're mired in the Apple ecosystem, not sure what I can do to help you, other than to extend a helping hand OUT.
terravast4 Nov 8, 2023 03:56 PM
step up to what ?
strutaeng Nov 8, 2023 04:26 PM
How about a Tech2 clone? They pretty much do anything. I believe works up to 2013 GM vehicles.
I got a handheld Innova from the local parts store, but wish I'd bought a Tech2 for the price.
Otherwise an Autel Maxysys (I think that's what they are called?)
It really depends how much functionality you want. Reading codes is not too helpful for diagnosis. Codes just tell you have a problem and which system is affected. Live data is better for figuring things out, as bi-directional controls such as having the ability to kills injectors while running or closing the bent solenoid.
RB04Av Nov 8, 2023 05:12 PM
step up to what ?
That high-$$$ ELM327 & Torque Pro solution. ;)
someotherguy Nov 9, 2023 10:40 PM
I use Torque Pro and the BAFX adapter for a lot of stuff, but it won't bleed the ABS on my '06. Neither will the $100-ish Launch CRP123 scanner. So forget about that. It won't do anything with the EVAP system on the '06 either. The Launch did help me determine which airbag impact sensor was bad though so it has its pluses..
Richard
strutaeng Nov 9, 2023 10:59 PM
Richard
EVAP codes?
Send me you ECU Brother 🙊...
someotherguy Nov 10, 2023 03:05 AM
Originally Posted by strutaeng (Post 5525630)
EVAP codes?
Yeah I mean it's a GMT800 so I have the eternal CEL thanks to the EVAP system. I do need to figure out what exactly is wrong though and fix it because when the tank is really low, it's a pain to fill it because it keeps clicking off the pump nozzle. Once it gets a little gas in it and I guess the filler neck gets a siphon effect going, it fills normally. Just a pain at first, every damn time.
Richard
strutaeng Nov 10, 2023 01:46 PM
Richard
I had the same problem on my OBS K3500 CCLB when I just bought it. I found the problem on accident when I was testing the purge solenoid on my suburban. I tested the purge solenoid on the OBS and it was dead. Technically, the valve that is supposed to control over this is the vent valve, but in that truck the problem went away when replaced the purge solenoid.
You can unplug the vent solenoid and jumper the connector from the battery to see if it works. I think it's normally open and applying power it closes? They can get stuck open or closed.
turboal1 Nov 14, 2023 04:58 PM
OBD2 Scanner
well i have a few of those ELM327 things in wired and WI-FI also a Samsung 9+ phone
that's Android powered, so all i need is the Torque Pro program. i guess it's online somewhere.
thanks all for the info
