No oil pressure
No oil pressure
I will try to make it short. Last year I bought a Keene Bell,and had a shop install and tune it. NO oil pressure, I was told the sender could not fit. They gave me a 45 to offset it, why they did not do it who knows! So this weekend I install it. Aggravated me every time I drove it, now still NOTHING! Is it possible that it was tuned out. The sender is brand new AC Delco, the connector was still there.
Thanks, Bill
Thanks, Bill
Thanks turboal for replying. I drove it a little today, and it stared working. Maybe it was just new and needed to get some heat in it? I thought the was wire cut, or something I did. It's the one wire stock gauge and mechanical was my next move. Cool truck by the way.
11 Second Club
That is a big NO NO! Once pipe threads are tightened, if loosen, the fitting must be resealed whether it’s pipe dope or Teflon tape ( and there is a right/wrong way to apply Teflon tape )
I’ve seen people go overboard with pipe dope/tape and actually clog sending units up
But for a piece of mind, just hook up a mechanical garage and verify that the motor is making oil pressure.
100% Redneck
He has oil pressure and driving the truck. He's getting intermittent readings most likely because of ground issues as I posted above. No need to waist time or money on a mechanical gauge until the ground issue is addressed.
Hi guys, I figured it out the sender was no good out of the box. It had ground and I tested it with air, no good. Put another one in from the dealer and now works fine 42psi hot at idle. I tested it with air before even before installing. The Keene Bell is a pain because they use silicone to seal the blower to the manifold. I almost went the mechanical route. Thanks, Bill
Justhereforinfo
32
05-30-2018 05:24 PM
thunder550
10-01-2006 06:08 PM
Cam51
14
03-05-2006 12:07 AM
1slow01Z71
22
09-15-2005 09:23 AM
ranwalk
01-08-2005 09:13 PM
