need some help built 383 89 c1500
Old Apr 20, 2013 | 01:18 AM
Default need some help built 383 89 c1500
i dont have a clue what sensors or vacuum lines i need on my engine so heres the run down ive been building a 89 stepside for the past 3 years and ive finally got it ready to go back together the engine is a 383 stroker built from a 93 block it has completely worked sportman 2 heads (perimeter bolt) with a edelbrock rpm performer intake, 850 chokeless mechanical second carb, edelbrock water pump (standard rotation not reverse im only running a waterpump and alternator no ps or ac.) msd pro billet hei distributor, elec fans, and a direct fit becool radiator and i have full length stainless headers. and a fully built 700r4 i said all that so you would know what set up im running so you might know what i need to do... i know theres a place on the headers for a sensor and a place at the back of the block behind the intake for a sensor or somthing and theres a vacuum on the brake booster... before you make fun im only 19 lol but any help/pics of sensor and vacuum locations would be greatly appreciated thanks!!
Old Apr 20, 2013 | 04:02 AM
CCrowell2's Avatar
Your brake booster can go to a big port on your intake for vacuum. The hole behind the intake next the distributer is for your oil pressure sending unit. The spot on the headers could be for egr or a 02 sensor, you can just plug it since you are putting a carb on it. Hope this helps ya.
nabozny21
Oct 17, 2015 07:47 PM
turbo6c3
Oct 5, 2015 06:11 PM
Mark_k
Oct 1, 2015 11:17 PM
jtphelps289
Sep 30, 2015 09:26 PM
DrX
Sep 29, 2015 04:31 AM
