Need help!! Wiring wideband into HP Tuners
I need some help getting my wideband wired in so I can log it in HP Tuners. I believe there are 2 ways to go about it. I have a working PLX gauge setup with a Bosch sensor for wideband and boost with the control modules mounted under the dash and I have the Pro interface with connectors on the side. I'm assuming the easiest way is to run wires from the module to the interface although eventually, I would like to wire it into the ECM for a cleaner, easier to use setup. Can anyone help me out on what I need to do? I should also mention that I'm extremely colorblind and I have zero faith in my wiring abilities. Lol! Thanks in advance!
1 Attachment(s)
My AEM wideband uses the brown and white 5v analog wires to connect to the HPTuners Pro interface. After data logging I just roll the wires up on the green connector and stuff it inside the fuse panel door.
There are some vids on Youtube showing the connection through the EGR wiring to the ECM. Attachment 154703 |
I'd recommend using the Pro connector since you have it.
1st pin is the feed from your WB. 5th pin is ground. Set it up in the scanner. You'll have to look at YouTube. Ed Motown has a really good video on it. |
