Misfire help
Old Oct 1, 2015 | 11:41 AM
00loudchevy's Avatar
Default Misfire help
Ok guys i had a head lifting so i replaced gasket and reinstalled everything and went to fire it up and i have a super bad popping in exhaust.. i changed coils.. wires plugs.. still have it.. took off valve cover and spin it over everything looks like its opening and closing good.. If i put my injector b fuse and start it will run with no popping once i put that fuse back in it takes about 5 mins before the pop comes back. At higher rpm it goes away but truck feels a lot loss powerful. Not throwing any codes yet. Any ideas on where to go next..
Old Oct 1, 2015 | 02:56 PM
Velocity1's Avatar
I'd do a precautionary compression test to better understand what may or may not be going on on that bank.
Old Oct 1, 2015 | 05:24 PM
Came up with 120 on each cylinder
Old Dec 3, 2015 | 05:54 PM
Velocity1's Avatar
Was that the first hit readings? Should be somewhere between 175-205 psi per cylinder.
legerwn
56
Nov 15, 2015 10:21 PM
bearden86
26
Nov 15, 2015 03:58 PM
Tydriver
45
Oct 23, 2015 09:19 PM
CammedZ71
11
Sep 9, 2015 02:05 PM
1bdbrd
Aug 23, 2015 03:24 PM
