Logging LC1 thru EGR
Has anyone done this? I cant figure it out for nothing.
ive wired in my LC1 and hooked it to the EGR signal voltage pin and cant get the readout to work right on my EFI Live. Does anyone have a script of the custom PID that you used?:bang: |
Sure man I can help you out. What analog output are you using? You are getting a readout of some kind just not right?
Whats wrong with your readout?? I use the lc1 and efilive v2
Im not getting anything on my egr voltage to start with. Which pid are yall logging?
Lets start there. I might have screwed that up from the get go. |
If the tune you are using did not have EGR enabled you need to turn it on, and also set the enable speed to 0mph and disable to 0 as well so it is always active.
Aight, ill start there.
Anybody have the EFI Live script? |
Or atleast a script that your running so i can compare to mine?
People with efilive just use one of the external inputs, ;) HPT standard doesn't have any inputs, that's why guys log it thought the EGR sensor.
it would be so much nicer to be able to log it without haveing to dig out that lil orange connector.
