Lean??
Old Jan 20, 2008 | 12:46 PM
Blue06's Avatar
Default Lean??
I got the converter and LT's with ORY on last night. Driving the truck I noticed when you stomp on it, it almost feels like it hits the rev limiter between gears..............but its only shifting at 5600. And when you let it go from a stop it barks, then hesitates for a second(like you let off the gas) Then goes again. What the hell is this?? Are my injectors maxed?? It is a LS1 swap with a small cam.
I'm putting the walbro 255 in today, and new feul filter (original with 68,000 miles) Think that will help??
Old Jan 20, 2008 | 08:51 PM
jakebdb56's Avatar
have you tuned for it? also, could be a transmission issue
Old Jan 20, 2008 | 09:01 PM
ridnlow's Avatar
My brothers truck did something similar when we put his LS1 in.. I had to reload a stock tune and go from there.. You need to let someone hook their scanning software up and check it out..
Old Jan 20, 2008 | 10:11 PM
Blue06's Avatar
I have had the LS1 in for about two months with the stock converter, and besides short shifting...it ran great. Now that the converter is in its like its getting fuel cut. I just put the 255 pump, and new filter in today with the Innovate LM1 wideband, so I'll take a look at the AFR.
Old Jan 20, 2008 | 10:12 PM
Blue06's Avatar
No tune as of yet. I'm waiting to put the MS3 cam , and Katech 243's on before I do that.
Old Jan 20, 2008 | 10:18 PM
ridnlow's Avatar
His was in for a while also and just one day started doing it.. It may nothing computer related, but I would def check out your AFR.. Did you break the converter in properly?? It needs several heat and cool off cycles before you beat on it..
Old Jan 20, 2008 | 10:55 PM
Blue06's Avatar
Converter is used, but just refreshened.
madmann26
Apr 29, 2020 09:17 AM
Pimpinpete
43
Dec 22, 2017 08:13 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Chevy305
Sep 28, 2015 09:21 PM
