Jeep Project having issues
Old Jun 13, 2011 | 03:47 PM
djbjess's Avatar
Default Jeep Project having issues
i have a project where I put a LS1 (L59 version of the LM7) out a 2001 Silverado. I am finding that the PCM is a 2002 Silverado (was supposed to be a matched set) and put it in a Jeep wrangler. It runs great but I am concerned with the gas (lack of mileage, about9 to 11 MPG)
I am running 4:10 gears, headers, cold air with 33’s x 12.5x 15 tires. It does not work hard to push this down the road.
I bought a wiring harness from EFI Connection. New O2 sensors (AC delco ) and a guy that I thought knew what he was doing cut the o2 connectors off at the harness due to the stock O2’3 are a flat 4 pin connector. The harness had a 4 box pin. Talking to the guys at EFI Connection they said that it was the same as a Camaro.
So to the real question:
Do I need to use the truck O2 sensors or should I use the Camaro O2 sensor?
Is the PCM different between the cars and trucks?
The Chevy manual shows that there are two type of O2’s
O2 with case grounded sensors
And
O2 with isolated grounded sensors
Which one would be needed?
Thank you
Old Jun 13, 2011 | 04:55 PM
djbjess's Avatar
I have found out that the PCM' s are the the same part# 12200411. So this would be down to the sensors. Thank you
Old Jun 13, 2011 | 08:47 PM
You need whatever sensors the pcm is programmed for either truck or car. Then order and install the correct OEM GM sensors
Old Jun 14, 2011 | 07:43 AM
SnakeOiler's Avatar
Front O2 sensors are flat plug, rear sensors are square plug.
I do not know the difference between a truck harness and a Camaro harness. I would have used a truck harness.
Old Jun 14, 2011 | 08:15 AM
djbjess's Avatar
Ok I am willing to go with that. How do you know which O2 it is programmed for? It came originality with the square one. and the guy that was helping said that we needed the Flat style. So I am just trying to figure out what is needed to make it right. (In short of buying a new harness) And they both use the same PCM. So it is a wiring reference as to what is done with the ground. I have the HP tuner and I could not find any reference other than turning them on or off.
Old Jun 14, 2011 | 09:50 AM
andrew383's Avatar
traveling mod
I assume the harness has an obd port??? See it you an hook up a scanner up and see if the o2's are even working before you go buy new ones...
Three6GMC
Oct 27, 2015 08:04 PM
livefast1
Sep 25, 2015 07:31 PM
FlowmasterMufflers
Sep 21, 2015 01:52 PM
custm2500
Aug 22, 2015 11:46 PM
Stainless Works
Aug 4, 2015 12:56 PM
