Initial Tune for 4L80E Swap
Old Mar 7, 2014 | 02:04 PM
Ferocity02's Avatar
Originally Posted by slowec
Smokeshow, wouldn't the segment swap have the 80e force motor part already right?
I was thinking the same thing. I'll have to double check that it got swapped over with the segment, not sure why it wouldn't.
Originally Posted by shupe
I find the xls and instructions in this link helpful.
Tool to help tune A4 shift points...
Nice to visulize what's happening when.
Great link! Thanks
Old Mar 7, 2014 | 03:56 PM
smokeshow's Avatar
Mod with training wheels
Any good links on more good trans tuning info?
Hasn't been the case in any of the 80e swaps I've done..
Old Mar 7, 2014 | 07:34 PM
MechE's Avatar
how do you turn off pwm?
Old Mar 7, 2014 | 10:13 PM
Truckshop's Avatar
Max out the min and max tcc apply tables.
Old Mar 7, 2014 | 10:18 PM
BlackGMC's Avatar
Resident Retard
I left my pwm working in my tune. With my triple disk it locks up pretty hard. The pwm helped soften it up.
Old Mar 7, 2014 | 10:20 PM
BlackGMC's Avatar
Resident Retard
Also i would set your WoT shift mph and your part throttle (90-100% tps range) alot lower than you want so it shifts based on rpm. Hopefully that makes sense.
Old Mar 8, 2014 | 12:00 AM
Ferocity02's Avatar
It appears that the Force Motor Current table carried over when I did the swap to the 80E segment.
Old Mar 24, 2014 | 02:05 PM
Ferocity02's Avatar
I noticed that there are quite a few differences in the DTC settings for the transmission between the 60E and 80E tunes. Most of the 80E DTC settings are "Non Emissions" while many of the 60E DTC settings are "2 Trips: Emissions Related". Some DTC's are not reported for the 60E and are reported for the 80E, and vice versa.
Should I go ahead and use all of the 80E DTC settings that are related to the transmission?
Old Mar 25, 2014 | 03:52 PM
slow67's Avatar
Gingervitis Addict
I would go with what the 80E has, as the 60E has 2 extra solenoids that the 80E doesn't have.
lycominghunter
Jul 29, 2015 04:24 PM
alex226
Jul 16, 2015 10:55 AM
lxcoupe
Jul 14, 2015 10:14 PM
NuckenFuts
Jul 9, 2015 08:45 AM
ALynch
Jul 6, 2015 09:49 AM
