How to test valve seals?
Old Nov 16, 2011 | 04:36 PM
Junkyard Dog's Avatar
Default How to test valve seals?
Short of tearing into the engine and removing the valve springs, is there any way to test whether the valve seals are bad?
Old Nov 16, 2011 | 05:45 PM
Steve-O-08's Avatar
Blue-ish smoke on start up is usually the sign of bad valve seals. There really isn't a way to test them.
Old Nov 16, 2011 | 06:14 PM
Gadgetized's Avatar
Why do you think your valve seals might be bad? What are your symptoms?
Old Nov 17, 2011 | 06:35 AM
skoal bandit's Avatar
pull your plugs. it helped my pin point exactly with one was bad.
Old Nov 17, 2011 | 08:18 AM
Good suggestion. Thanks.
As to why I think they might be bad, well, I have oil smoke on start up, but, as explained in my other thread on that subject, this happened last winter for a month or so and then just went away. No more smoke on start up and no oil consumption between oil changes. Now it is happening again, 8-9 months later. I do not think valve seals go bad and then fix themselves for almost a year and then go bad again.
This is why I am looking for a way to test them.
Thank you one and all for your input.
Texas5.3_1251
Mar 5, 2016 08:10 PM
chopperloco
Sep 28, 2015 08:40 AM
TrickTurbo
Sep 23, 2015 08:41 PM
cousblake11
Sep 9, 2015 06:52 PM
fctry286
Sep 5, 2015 11:48 AM
