Hard starting issues
Old Jan 26, 2012 | 08:52 PM
TA63's Avatar
Default Hard starting issues
I have a 2000 2500 with ported and milled 317's, EPS 218/226 cam, long tubes, and a custom tune. I swapped this engine in 3k ago due to hard cold starting issues. It also burned a lot of oil. The new engine runs like a champ and has good power, but the hard starting issues remain. Its like starting a carbed vehicle without a choke. It spits, sputters, and nearly dies for about the first 20 seconds then levels out. This only happens when cold. Any ideas?
Old Jan 27, 2012 | 05:08 PM
MikeGyver's Avatar
It's in the custom tune.
Old Jan 28, 2012 | 03:55 AM
TA63's Avatar
What should I be looking at in the tune? The thing that is driving me nuts is the old engine with a stock tune started hard just like this one. Would deleting the EGR possibly cause this?
Old Jan 28, 2012 | 08:56 AM
MikeGyver's Avatar
You didn't say in the first post that the old engine was on the stock tune, so to keep others from jumping to a conclusion like I did, we are going to need more info: What parts did you keep from the old engine for the swap? Injectors, EGR, throttle, FPR, intake manifold, engine temperature sensor, etc, etc.
Old Jan 28, 2012 | 05:17 PM
TA63's Avatar
The only thing swapped over to the new engine was the intake, throttle body, and associated sensors. The injectors are 8.1 marine units. I replaced the idle air control valve on the drivers side of the TB with no reults.
Old Jan 28, 2012 | 07:31 PM
andrew383's Avatar
traveling mod
Start with checking the fuel pressure,key on and while starting and when idling
Old Feb 1, 2012 | 11:14 AM
Vortec350ss's Avatar
I am having a similar issue. I know its due to fuel pressure. I don't have a gauge, but I know this is because the tank is not under pressure (vacuum) when it is first started. I know this is the issue because it almost dies when I take the fuel cap off and the truck is still running. I hear air rush into the tank, and it almost dies and starts runnign really rich. I can also tell that it starts to run pretty lean when I cap it back off at first too.
Any suggestions here?
Thanks,
Rob
SLOPONY
20
Oct 18, 2016 06:05 AM
05GMC4.8
Aug 7, 2015 09:55 PM
steves86ta
Jul 28, 2015 10:21 AM
banker099
Jul 4, 2015 05:50 PM
