Full throttle log
Old Feb 5, 2006 | 09:43 AM
KySilverado's Avatar
Default Full throttle log
Guys have a look and let me know if you see anything that needs immediate attention.
Couple things I've noticed. 1> I still have some TM in it. Although I thought I had removed it. 2> I need to work on the fueling a bit. Starts out 920 mv on the o2's down to 890's at the end of the run.
I also have always gotten this odd bit of KR. Never any KR at WOT. Thoughts?
Old Feb 5, 2006 | 10:36 PM
Kano's Avatar
looks like some burst knock in the wot run
Old Feb 5, 2006 | 10:46 PM
02sierraz71_5.3's Avatar
trims need work they should be within +-5 at part throttle, that will help with the spuradic kr in the second pic
bump the pe fueling gradually by .02 up towards the higher rpms to stay away from lean conditions.
If you go with anymore HP adding mods I would upgrade injectors, are these the injectors that cam with the radix kit?
Looks good
Old Feb 6, 2006 | 05:47 PM
Looks good
My LTFT's are a bit lean. In the area of the KR averaging -6 to -8. I do need to work on this a bit. Was wondering how much to tune the pe fueling. Thanks for the input.
Yes they are the 43#ers that came with the radix and you're right it appears I am reaching their limit.
Old Feb 6, 2006 | 06:06 PM
virgils4.85spd's Avatar
Default Injectors
90 percent injector cycle. Close but not really dangerous yet.
Derek
chvy=power
Sep 8, 2015 11:05 AM
KleanKustoms
Aug 27, 2015 10:16 PM
wheeliE-maxx
Jul 19, 2015 05:37 PM
bsgiffor
Jul 19, 2015 11:14 AM
