fuel cutoff or rev limiter problem - 05 rcsb 6.0 t56 -
Hey guys, posting up for answers or opinions. I'm very new to this. I've got a 2005 rcsb with a 6.0 lq9 tsp stage 4 truck cam, prc heads shaved .020, walbro 255 pump,8.1 injectors. Swapped in a t56 from a 02 ss camaro as well. I've changed everything in the tune to bump the rev limiter I can find. I'm still bouncing off it for some reason. You guys take a look? Also, this is a work in progress - I've got it idling great and taking throttle but I haven't done any ve tuning or maf tuning yet. I've got a aem 30-0300 wideband hooked up in the truck but I haven't started logging it in hptuners yet. I'm open to any suggestions, or tips. Thanks in advance.
I can't view the tune file as I'm using 3.6.26 still but did you disable the drivetrain abuse settings on the engine side and the transmission abuse settings yet?
Also I highly suggest not running it all the way to redline if you haven't done any airflow model corrections yet.
I know I did on the engine side but didn't mess with trans side because its a manual. Ill check after work today and post up. I just upgraded to newest version the other day. Noticed a few changes in the editor tabs so far. Thanks for the reply.
I've been monitoring the wideband when going wot and it doesn't appear to be very far off anywhere in the rpm range I see 14.2 to 15.0 while not in pe and around 12.7 to 13 while in pe. I've never seen any kr through a pull. I'm sure its not perfect but its hard to keep my foot out of it.
Got the issue fixed. Was under engine fuel cutoff in gear. I raised all the gears but park and neutral or reverse. Being a manual I should have raised the park/neutral. Its fixed now. Thanks for the help.
stall speed
10-05-2003 01:22 AM
