Fooling the egr???????????
I just dropped a newer 5.3 motor in my wife's Burban, but new motor has no egr, she is throwing a code.
Can I run a jumper at the plug to fool it or do I have to buy a programmer? I could always put the old egr on, but that sounds like like a lot of work! Thanks Gb |
you would need to disable the code via programmer or newer PCM that wont look for it.
If your in california theres a good chance you will fail smog since the truck originally came with egr. California sucks, it dosent matter that the new motor didnt use it the smog equipment has to match the truck. Hopefully the smog tech will be in a hurry and not notice it. I just did a 6.0 swap a few months back and i had to keep everything that was originally in the truck, even the AIR injection which meant i had to use my old exhaust manifolds.
We can make the correct adjustment so it will pass the emissions test
I would tune out the EGR codes and put in the GM parts to block off the EGR parts.....makes it basically factory. The later non-EGR motors have the same heads, cam, intake, etc.....
Originally Posted by CalEditor@PCMCalibrators
(Post 4875404)
The problem is the sticker under the hood will say that the car has the EGR, and the smog tech, if he has it head out of his ass, will be able to visually see that there is no EGR. It would pass the diagnostic test like you said I imagine. If there is no sticker I think they can still look it up in a database by VIN. Someone correct me if I'm wrong. |
Originally Posted by Ferocity02
(Post 4875788)
Is this is true I'd remove the EGR today.
You can disable the EGR and tune it so it shows that is has passed the readiness test
(Post 4875838)
I was under the impresion the emissions go with the newer of the 2
| All times are GMT -5. The time now is 10:09 AM. |
