FJO/EFILive
Old Jan 9, 2008 | 10:00 AM
Default FJO/EFILive
I have worked with the Generic SAE Calculation for the FJO in EFILive and i have not had any positive results with AFR logging for AutoVE. I have checked the 0-5 volt signal from the FJO and verified the connections to the scan tool (V1). While viewing the FJO software and EFIScanTool and simotaniously monitoring both, the EFI log appears very lazy in AFR compared to the FJO log. Also if you watch the analog voltage in Data it is very responsive to additional fuel and will drop to around 1 VDC very quick, so it is does not appear lazy in that respect. Is there a calculation out there that will correct this or do i just need to purchase and LM1 or LC1. Any help would be appreciated.
