fan swap ecu programing
hey all
did a efan swap over the winter now that summer was here couldnt get the ac to go on till i found out the ecu needed to be set up for A/C
now a/c is working and the fans come on but when its time to kick on hi speed the relay for it is getting pulsed signal (hear the relay clicking)
wrong setting? whats causing this?
Have you verified the signal (voltage) going to the relay from the PCM? If that current is constant, I would bypass the relay altogether to see if the fan comes on. I just had a relay go bad on my E-fan harness after my new motor was installed and that's how we found it.
hey all
Same thing happened to me with my swap with a van pcm, Relay would just pulse, changed the setting to "fan 2" now all good
