Engine wire diagram
Does anyone know a reliable place to download or get a copy of a wiring diagram for the engine wire harness on an 04 and 00 5.3 silverado 1500?
I have some somewhere. Let me look thru my photobucket.
Why would you need that if your the fastest truck ever ??? :punch:
The fastest truck ever g
The fastest truck ever got wraped around a telephone pole that wouldent move out of my way. Now the motor is going into a 2000 short bed single cab
Its not working right on my phone.
When i get to some internet on the laptop ill post up the pictures and you can save them. What exactly do you need? I have the pcm pin outs and also the fuse box connector pinouts. |
Thank you so much nonnieselman. Both would be awesome if you could. I put an 04 motor with an 04 harness into a 00.
Originally Posted by Fastest Truck Ever
(Post 4817156)
99-02 cable style PCM is listed here. Wiring Diagrams - The 1947 - Present Chevrolet & GMC Truck Message Board Network If you used the 04 harness With the 04 PCM then I will Suspect you will need the Fuse block Pin out as well... |
This guy has some wireing info for both the 99-02 and the 03-05 PCM harness
Vortec 4.8/5.3/6.0 Wiring Harness Info |
| All times are GMT -5. The time now is 08:26 AM. |
