EFIlive noob. Truck wont idle
Truck is a 03 1500 2wd. I just swapped the stock 4.8/4l60 for a 6.0/4l80 with a small cam. 226/231 .605/.598 113+4. I figured out how to do the segment swaps for a stock 6.0 and 80e and it came right to life the first time I hit the key. It idled and sounded good. Only code was random misfire. I installed a AEM wideband and the driveshaft today and had hoped to take it for a first drive to see what the air fuels look like but it couldnt maintain idle once it got warmed up. I know nothing about tuning a gas truck. I have been playing with diesels for years and thats why I have EFIlive and would like to learn it and continue to use it. Hoping some one can help so I can get it on the road to start logging and making small adjustment because as of right now I cant drive it.
TOTM: January 2007
Add a 3-4 grams of base idle air. Set 20 degrees of timing in P/N and In-Gear tables up to .44 g/cyl and 1200 rpm, and then blend (linear fill). Monitor idle trims and idle spark to see what it happening as the engine warms up. Too much idle air, you will see lower than commanded timing to order to achieve target idle RPM. Opposite for too little. I prefer less timing and more airflow so the there is more instant torque reserve (timing) available to manage idle speed.
If it runs bad warm, check your O2 trims (STFT) and adjust your MAF and VE tables accordingly (usually take airflow out). Make sure there are no intake or exhaust leaks that are being picked up by the O2 and flooding the engine as a result due to a fake lean condition.
This should get you going.
Liftedsilvy
10-03-2011 11:45 AM
gmcswb199
11
11-10-2009 07:53 PM
endo
06-08-2009 06:24 PM
Blown02Sierra
06-03-2006 08:08 PM
ThunderZ28
23
02-05-2006 11:13 PM
