draining battery
Old Dec 29, 2010 | 05:45 PM
sprayedenali's Avatar
Default draining battery
so i moved my battery to under the bed and ever since i did that it always slowly goes dead. if i leave it connected for more than a day or two without driving it a good bit its dead... so theres something going on somewhere to make it constantly pull some current to drain the battery.
anyone else ever run into a similar issue?
Old Dec 30, 2010 | 06:51 PM
MikeGyver's Avatar
Is there moisture on it maybe?
Old Dec 30, 2010 | 07:18 PM
Gadgetized's Avatar
The best way to find this is to use a circuit tester/test light. Remove a battery cable. Connect one end of the test light to the cable you just removed, and another to the lug it was removed from. If there is a draw, it will light up. You can start pulling fuses to find where the draw is. When you pull the fuse where the draw is, the test light will go out. Don't do this test with any accessories on, hood light, dome light, brake lights etc.
Old Dec 30, 2010 | 08:45 PM
Rhino79's Avatar
9 Second Club
Ditto,
I run into this on marine products all the time. Should be fairly easy to narrow it down to the area thats givin you fits. From there it could be wiring, connector or a component.
Idryfly5
Sep 2, 2022 08:55 PM
RustyD
May 23, 2016 07:04 PM
kalikid06
20
Oct 13, 2015 07:37 AM
Slammed silverado
Sep 28, 2015 06:14 PM
lxcoupe
Sep 25, 2015 12:36 PM
