-   Tuning, Diagnostics, Electronics, and Wiring (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/)
-   -   DOD delete??????? (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/dod-delete-477597/)
99s10sbc Feb 14, 2011 12:38 PM
DOD delete???????
I dont understand why you need the dod delete if you disable it threw tuning
06MonteSS Feb 16, 2011 10:46 AM
you don't...
a simple change of one value in the tune file and the DOD/AFM is completely disabled...
BUT, that "DOD Delete Kit" that the other thread is talking about, is to remove it altogether and upgrade the engine internals... they're not doing all that just to disable the DOD/AFM functionality...
Lloyd-TX Feb 16, 2011 12:09 PM
Originally Posted by 06MonteSS (Post 4643611)
you don't...
To add - the AFM/DOD lifters are notoriously noisy and fragile.
99s10sbc Feb 18, 2011 07:28 AM
I have a predator and it says disable dod turn it off and it still goes from v8 to v4.
j_ahlheim Feb 18, 2011 07:36 AM
the main reason people remove the dod lifters is because they install higher lift cams and the dod lifters have been known to fail with aftermarket cams. Stock cam you will be fine.
Coban Feb 19, 2011 05:05 PM
Originally Posted by 99s10sbc (Post 4645389)
I have a predator
There's your problem.
skoal bandit Feb 20, 2011 11:10 AM
exactly what he said. lots of people are installing bigger cams with high lift.
hog Feb 23, 2011 05:56 PM
there are still a lot of people that disable DOD based on ignorance.
peace
Hog
06MonteSS Feb 24, 2011 02:39 PM
k.. when you highlight OFF, did you then press the center button to SAVE the selection, and then press the ESC button a few times to back out to the main menu until it asks you to "Install tune now?" - then you select YES and reinstall the tune with the change you made??
