-   Tuning, Diagnostics, Electronics, and Wiring (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/)
-   -   Do I weld it here? (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/do-i-weld-here-495186/)
kr1s Jan 14, 2012 03:18 PM
Where to weld Wideband Bung stock manifolds and Y
So do i weld the bung here?
http://i1115.photobucket.com/albums/...ld/Doiweld.jpg
AKlowriderZ71 Jan 14, 2012 03:28 PM
Yes. Make sure that you put it somewhere that the sensor won't be interfering with the body. Hold the sensor up there so you can see how much room you need. Then make a mark with a Sharpie, and remove the y-pipe.
kr1s Jan 14, 2012 03:44 PM
:) got it! already marked just need to take off the Y
Gadgetized Jan 14, 2012 03:57 PM
The main thing you want to remember next to accessibility is the clock position. It is suggested to weld it at least the 9-3 oclock position or above. When there is moisture in the pipe it will be in the lower portion of the pipe, and you don't want a WB to get wet.
kr1s Jan 14, 2012 05:32 PM
That being said i can weld it straight up then? at a 90 degree angle?
and it also says to put it at a 15 degree angle away from the flow of the exhaust
AKlowriderZ71 Jan 14, 2012 05:37 PM
Does this help at all?
http://i557.photobucket.com/albums/s...ndlocation.png
kr1s Jan 14, 2012 06:15 PM
Yup thanks man, lol it shows almost the same picture on the little user manual
Which pin am i gonna change on the pcm?
I also got some k5k capacitors, but what are they for?
AKlowriderZ71 Jan 14, 2012 06:17 PM
I'm not sure what you're asking here?
kr1s Jan 14, 2012 06:20 PM
I'm not gonna pin anything to the pcm?
How am i gonna log the wideband to efi live, sorry if i sound kinda dumb
AKlowriderZ71 Jan 14, 2012 06:24 PM
Ok. I'm not sure how you connect the WB to EFI Live. I use HPT pro, and it connects to the HPT cable for datalogging. Which version of EFI do you have? One of the EFI guys should be able to point you in the right direction.
If you don't get a response in this thread, search or post a new thread in the tuning section.
