cranking problem
#42
Pretty sure I found the problem now. Sorry I didn't post up the HPT file earlier. Your cat light off is taking the idle in park timing and multiplying it by 2.5 and thus making it 60 deg of timing at cranking. Zero the table out and you'll be fine. Or look at what I did to this tune. Reflash your PCM with the one I attached and it should fix it. Sorry I didn't catch the fact in the first post it was 62 deg of total timing. I swore I never saw that when you originally posted this. Reflash PCM with this tune and report back in the morning. PM me with a phone number if you need me to explain.
#45
your not running E85 on that tune file you posted up are you?
if so there are a few things that need changed if you are
no the injectors are new with this engine, i thought that was a possibility, and still could be. I have a pcm with a wheatley tune in it and my original with my tuning in it. I am running e85 now so once this tank is empty if i don't figure it out by then i am going to switch back to gas and try that again. it can sit for hours when its warm enough outside and it will be fine. i let it sit in the shop at work for about 5 hrs last night and it started fine, only has problems when the motor get below probably 45-50 degrees. Also is that amount of timing correct? i will post a log when i get a chance.
#48
11 Second Truck Club
no, i scaled the injectors down by the percent that the difference between the stoich ratio of gas vs e85 is, seems to run good, trims are same as with gas and wb shows 12.8 WOT but im not an expert, if you are willing to share something im missing, that would be cool!
#50
