Couple Questions
Old Feb 23, 2006 | 10:34 PM
SBChvy's Avatar
Question Couple Questions
Hey guys, whats up. Im in need of a newer pcm (2000 ), I'm looking at getting an 02 pcm from somewhere. I currently have the superchips on my truck-can I still use it with the different pcm-or will the vin# change. If i cant use it then how much will it take to make it work(clear code) . I talked to a superchips rep and he said I dont need a re-program even if its a completely different vehicle-I call bull on him. Whats your take on it.
Also I plan on getting HPTuners-what should I use to order it now that the pcm is different. Will it even be a problem?, and what are you guys getting-standard or pro, any options with either? I wanted to use the superchips program as a "base tune" if I can-good or bad idea?
I should also add that sometime in the future FI will be introduced and possibly an engine/tranny swap.
Thanks a lot guys-
Andy
Old Feb 24, 2006 | 03:06 PM
SBChvy's Avatar
To the top-I got it mostly figured out. But what are you guys getting for a program Standard or Pro.
Old Feb 24, 2006 | 04:14 PM
Zick's Avatar
Thanks a lot guys-
Andy
I believe the Superchips is married to the VIN, but don't quote me on that. So if you buy a 02' PCM, then it will have a different VIN #, unless you get someone to reprogram your original VIN to the new PCM then it *might* work.
As for the HPT, If you get the 02' PCM you will have to order HPT for a 02' model.
Standard or Pro is really in how much do you have to spend. I can tell you that once I got my EIO & WB hooked up it was ten times easier to tune the VE table.
Old Feb 25, 2006 | 09:06 AM
SBChvy's Avatar
What did it take to do that-I take it that you have Pro then.
Old Feb 25, 2006 | 10:22 AM
Zick's Avatar
Well I got mine from a member on here before they started in with the standard and pro series. So now I guess it would be considered the Pro model.
Basically all it takes is to have a wideband (LC-1 for cheapness) and the EIO adapter. Then just install the WB and wire it up to the EIO and tune away.
Old Feb 26, 2006 | 02:57 PM
SBChvy's Avatar
Nice thanks for the input man.
The_W
Oct 28, 2015 09:00 PM
Noah Burns
Sep 7, 2015 05:50 PM
JFortner5
Aug 24, 2015 10:32 PM
Jblake
Aug 17, 2015 12:59 PM
USMCvet0311
Aug 1, 2015 07:45 AM
