-   Tuning, Diagnostics, Electronics, and Wiring (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/)
-   -   Code Help..... (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/code-help-400626/)
dewmanshu Sep 9, 2007 08:16 PM
Seems to be a thing these days, those codes. Jesus Shannon, that's a shit load of diagnosing.
Seems from research I've done and those above diagnoses say the same thing. Clean the grounds for your EBCM. I have those codes (not exactly but for the most part) and I'll tell ya, a PCM didn't fix mine.
CHEVRACER83 Sep 10, 2007 02:16 PM
better to have too much info than not enough :jest:
dewmanshu Sep 10, 2007 03:21 PM
yes, yes sir this is correct most of the time, except for ADD fuckers like me.
CHEVRACER83 Sep 10, 2007 04:51 PM
THERES ALWAYS AN EXCEPTION TO THE RULE :judge: :jest:
BradS Sep 10, 2007 09:22 PM
so where do I find this ground? Is that the box under my driver side that causes the abs pump to run all the time when it goes out?
Grumpy5.3 Sep 10, 2007 10:08 PM
the ground you need is under the drivers door. It is bolted to the part of the frame that holds the body mount bolt. It is the one with 2 wires going to it. Just clean off the goop, and put a star washer under it, and tighten it.
BradS Sep 17, 2007 02:13 PM
Well I cleaned the battery terminals and changed the pcm. Problem solved. Not sure what fixec it but it hasent done it in 4 days and it was doing it everyday.
Im going to check out the PCM to see if that was the problem -- if it wasent then I will have one for sale soon
