4l80 swap
4l80 swap
Edited: all info on this post..
Attachment 139809
How to swap wires.
Transmission connector:
Attachment 139810
Remove cover:
Attachment 139811
Attachment 139812
Remove white end:
Attachment 139813
Small knife works good to bend the lil grey clip back to remove the ends:
Attachment 139814
Put the white piece back on, the grey cover, and your finished, that easy.
Attachment 139815
After all that work,,, i think this 2004 harness is already a 80E harness
Attachment 139816
Attachment 139809
How to swap wires.
Attachment 139810
Remove cover:
Attachment 139811
Attachment 139812
Remove white end:
Attachment 139813
Attachment 139814
Attachment 139815
Attachment 139816
Custm2500's Rude Friend
Wiring mods...
Remove K(orange), V(light blue), S(white), T(tan/black) and U(brown) wires from transmission connecter. Move U(brown) wire to the S location.
Front Input Speed Sensor (ISS) is made by using the orange and light blue wires. Add a VSS connector, connect orange to terminal A and light blue to terminal B. Move the low signal wire from pin 45 to location 26 in the TCM harness.
Install the front Input Speed Sensor wiring connection
Install the shift selector switch on the driver side you removed from the 60.
The factory speed sensor can plug back into the 80e tailshaft sensor
PCM/TCM...
Conversion is finished, had to get a 2008 Chevrolet Express 4.8L/4L80e van C2500 TCM tune to get the transmission to shift correctly. There was nothing special done to make the TCM work in the Silverado, just swap them out. The TCM was loaded with a factory tune for an 80e transmission.
Type: Chevy Express (V8) 2008
VIN: 1GCGG25C481106014
TCM...
Segment 1: 24239927
Segment 2: 24235887
Segment 3: 24251658
Segment 4: 24235883
Without the 80e TCM tune there was no speedo output to the PCM and the tune would not enrichen the fueling when accelerating.
Taken from here...
http://www.ls1truck.com/forums/power...on-gmt900.html
Shawn87 (01-06-2021)
4l80 swap
1fastbrick
Sorry it won’t let me reply to the original message for some reason. But I already have my 45 pin moved the 26 on the TCM pin side I’m just not familiar with this year with the V. U. And S. coding on the plug?
cdub81
05-23-2013 06:44 AM
sss408
11-04-2012 06:50 PM
snowshoejeep
09-03-2012 01:04 PM
