Cant figure this out...
100% Redneck
Are you sure the throttle is closing all the way leaving a little slack in the cable? If it's closed and sitting on throttle stop screw... back off the throttle stop screw starting with around half a turn. Unplug both the IAC and TPS sensors > turn key to the on position (no start) for 30 seconds > turn key to the off position > re-plug the TPS and IAC sensors > start engine and see if the idle has dropped. Repeat adjusting the throttle stop and resetting the sensors (as above) until you have a stable idle. The correct way would be setting the IAC counts in HP Tuners scanner software using the same procedure as above.
40oz (01-15-2021)
makes children cry
at first, it reminded me of when i removed the EGR & forgot to plug the hole in the side of the intake manifold... except yours stopped before 2000rpm & went down. mine got above 5000 before i turned the key off (at 10pm... in the middle of base housing... with an open Y-pipe)
i agree it's likely an idle air control or throttle blade issue
slonlow2000
19
03-31-2017 03:30 PM
